TTMR not working
Asaddoris
May 2018
Georgia
19
Hello everyone,
So I am currently trying to write some logic to a program that was not written by me.
I am using a Mitsubishi PLC (QO6UDV) and writing the code using GX Works2
I am needing to create a cycle time for the machine process, to measure the amount of time that the process takes. So I have the code written and I found that it was easiest to use the TTMR function due to it will continue to count until the enable bit is no longer active.
When I run the PLC simulator, and toggle the enable bit, everything works great, no issues and is what I am looking for.
When I load it into the PLC and try it in real life, same enable bit is active, but the timer will not time. Not sure why and I called the tech help which was somewhat of a joke and got absolutely nothing from them.
I have attached a screen shot for the logic that I wrote.
Is it possible that you are programming a FX series instead of the Q series?
The TTMR instruction is different in each of the units.
Just a thought.
Regards,
Appreciate the reply, but all my PLC's are Q series. I think I might have found another option, haven't tried to load it into the PLC yet, but the simulator works. I replaced the TTMR with a DINC, only problem now is resetting the count to zero after cycle is done.
I am creating a project with WinCC Unified v16 Upd6 (PC runtime) with an S7-1200. The communication is good between the PC and the PLC as I can...
205
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
347
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
62
Has anyone ever seen where you have a tag reading from the plc in scada. In this instance it's just a PEC, I set it up on one scada terminal and...
100
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
188
