Turck BL20 Programmable Gateway
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,807
I ran across a problem with a system done by others using a Red Lion G306 connected to a Turck BL20 Modbus TCP programmable Gateway.
They are experiencing a problem with the HMI showing a screen that says "PLEASE CYCLE POWER". Best I can tell from the G3 programming this is driven by a bit address in the PLC.
So I have some questions about the Turck PLC. Apparently I need Codesys v2.3.5.8 to communicate with it along with the BL20 target files.
I found a codesys store, registered, downloading software now.
My question (now just one as I found some things while typing this out):
Can I upload the logic from the BL20 without having the original source code?
I am sure once I get this installed, I will have more questions. Thanks.
When using Turck BL20 analog and Siemens S7 can someone tell me if the scaling in S7 is still 0-27648 (for 0-10vdc/4-20ma) or is it something...
1,859
hi there! i am trying to read modbus registers in M340 PLC from a Turck BL20 Gateway. I have done this with a Emerson Gateway and everything...
1,975
We have a PLC system running a conveyor. The PLC system includes Turck BL20-GW with RFID-2 card. I am about to add a DI card to the BL20-GW...
4,524
I have been Tasked with wiring an i/o link block to an existing machine, and use a few proximity switches and a q4x laser distance sensor to...
445
Hello Experts, I have a Turck Encoder connected to P+F IO Link master communicating over Ethernet/IP with Allen Bradley PLC in Studio 5000 v34...
739
