Turn off the PID or let it Run?
BillRobinson
Oct 2006
Sydney, Nova Scotia
185
I have an emergency bypass valve that I need to control around a flow using a PID loop. Just to give it a number, let's say that I need to open a valve is the flow is greater than 80; so 80 is the PID setpoint. Now lets say the flow is typically around 10-20, so if i use a PID loop it will nearly always calculate an output of 0%. This seems like a lot of unnecessary calcs for nothing.
So should I use the PID all the time or should I just turn it on when PV reaches 70? Any opinions?
I would leave the PID on.
There is nothing wrong doing what you are thinking about but the PID may start coming off of saturation 15 degrees from the set point. This may avoid overshoot where your arbitrary 10 degrees may not give the PID time to 'slow down'. This would be especially true if you are using the derivative gain.
Hi, I have a 1500 that controls a station with diferents warehouses, but i also have a 1200 that controls one of those warehouses, i have been...
281
Trying to make a bit or a lamp Iv tried both turn on when the robot drops a unit into a bay and turn off when the worker oushes it back out to the...
1,784
Hi all, Learning the FTView ME software and have come across an issue: I have a latched process start button, a stop button and a pause button...
8,080
Good afternoon, I have a motor running on a machine and whenever I cycle power on the PLC, the motor stops and comes back on when the PLC turns...
31
9,334
Hi All, I have a ControlLogix PLC with v13. The client requires to swap 1756-OB16 module with 1756-OB32 module. From documentation, I have found...
3,090
