Tutorial on this site
weilerot
Nov 2004
19
I am new to this site. Trying to learn ladder logic. In the online tutorial "level application" should the two contacts on the first rung be normally closed? The tutorial says that when there is no liquid in the tank that the circuit is on. Seems to me that the contacts should be closed so the pump motor can start
The contacts are shown as they would be for a normal 'real world' relay, that is, they are shown in a state of no power (not energized) applied. As you point out, the description of the EXTERNAL circuit sensors says that thes inputs will be turned on when there is no fluid covering the sensor. In that case the external sensor will turn ON, the PLC's input will be turned ON and the state of the contacts show will then be true.
This is NOT shown while runnning by changing the normally open (NO) symbol ( --| |-- ) to normally closed (NC) ( --|\|-- ). In most PLC's it is shown by highlighting the contact with a contrasting background. This highlight means the contact has now switched from the state of the graphic symbol (its OFF state) to the opposite one. So in this exercise, imagine this highlight on the input sensor symbol expressing a NOW closed state.
Damn you're good, Allen!...
As I was reading weilerot's post, I vaguely remembered addressing that same question a while back... :unsure:
Sure enough, you found the thread... :cool:
beerchug
-Eric
I just finished putting together a new PLC How To site: PLCHowTo.com It's a set of tutorials aimed at people new to PLCs, introducing key concepts...
2,632
Hi. I am trying to understand some old code for B&R 2005 PLC created in PG2000 software. There are procedures concerning axes but I cannot find...
727
I'm testing the ability to make a custom ActiveX control for PVP7 applications to be able to write data out in an XML format. With my simple...
701
Hi guys, Can you share me any educational links & tutorials for B&R PLC structured text programming? The help section in their automation...
854
Hi all, PLC machine vision is barely talked about anywhere yet it is very important PLC and Industrial automation topic. Like you see vision...
1,064
