Twido Simulator Won't regester additional I/O modules
Volvagia720
Oct 2012
Minnesota
I've just started programming with the twido software, and I am unable to get the simulator to change the inputs, or monitor the outputs of the add on modules. I can do just fine with the I/O on the main portion of the plc. The digital output module doesn't signify whether it's outputs are high or low. The analog input module, doesn't allow me to change the input, I don't have control of a slider, and it shows the input as "-" instead of a number.
I'm using a TWDLCAE40DRF plc with the following modules TM2DRA8RT, TM2AMM6HT.
Windows 7,
Latest Twido Software
Hello!
I tried the modules you say right now in my twidosuite (last version, win7) and all it´s ok.
Take a look if you configurated the analog input and output.
If you don´t configurate, the "-" will apear and you can´t change the value.
By configurated, I assumed you mean that I did the setup in the configure hardware portion of Twido. I have the analog inputs setup as 4-20mA, and i have the scaling where I want them. If there's something else I have to do to configurate them, I'd love to know where to do this at.
The only thing I hate more than a problem, is a problem that solves itself overnight. I opened my project this morning, and when I simulated it, it was working. I even remember the last time I worked on it, it wasn't working.
sounds like you did a power gown cycle that may have cleared the issue
Hi guys!! I'm New here and new with this type of plcs i have TWDLMDA40DTK and i need to get a copy of the program and i don't have an original...
698
Dear friend, how to read the input register (3xxxxx) of device from twido plc. i have tried the comm macro but it always read the holding register...
1,573
Good, how do I control through an Analog output of a valve, that is, open the valve from 10% to 10% until it reaches 100%, and then close it...
2,251
Hi! I bought a secondhand Twido base unit to help me learn programming and also faultfind expansion modules (one of my customers machines uses...
1,701
We're a second hand machinery merchant. We've just had a machine arrive that has a Schneider Twido TWDLCAA24DRF PLC and a Magelis XBT-R411 HMI...
2,419
