TwinCat 3 - connection to softPLC
italo2008
Feb 2009
Padova
95
Hi All
I am not very skilled on TwinCat
This is the situation: We are switching from phisical PLC (CX5120) to softPLC (we use HMI, that is a win10 OS industrial PC, for both Scada and SoftPLC).
I installed twincat on PC (HMI), and my PLC application is running and communicating with Scada.
What I'm not able to do is connecting with my laptop and go online with SoftPLC, I can only open twinCat on HMI and working with remote desktop.
I can see the softPLC on the window that you can see in attached screenshot, but i can NOT connect to it. If I try to click on "add route", it asks for credentials (As usual, I put "Administrator" and "1"), but then nothing happens, neither error messages nor "X" or other drawings under "connected" column
any suggestions?
Thank you
You need to setup the firewall so that it does not block the ports needed by the ADS routes. This is documented somewher ib the Beckohff help.
The Windows firewall would be the first thing I'd check.
Also, the Administrator/1 login is the default for Beckhoff CX devices. Since you seem to be using some other brand of industrial PC/HMI, be sure you are using the Windows login credentials for that device when adding the route.
Hi, I have an odd problem that consumes a lot of precious time. I will often lose contact with the TwinCAT System Service, and be completely...
1,370
Hi everyone! Have anyone connected a PLC Beckoff using Twincat 3.1 software with Movicon 11.5 visualization (from PROGEA)? If yes, there is any...
1,723
Hi, I'm Vinicius I've just started working with TwinCAT and Beckhoff PLCs. My question is about connecting the PLC to the software. This morning I...
5,194
I am running 2 Beckhoff Industrial PC's that are identical, just different computer names and IP addresses. I connect remotely using “Choose...
3,453
Hi, I have a Beckhoff plc connected to a GPRS modem with static IP address. I like to connect TwinCAT to PLC from remote site, but I belive I...
2,689
