Twincat 3 error then use string as variable name
r142dm
Jun 2018
Hestra
Hi!
i try to use string as variable name in a forloop my problem is tahat my if insturktion not allow strings as variable name.
my declaration is
var
aForSend : ARRAY [1..3,1..6] OF STRING;
bSmsNr1InUse : BOOL;
bSmsNr2InUse : BOOL;
bSmsNr3InUse : BOOL;
bSmsNr4InUse : BOOL;
bSmsNr5InUse : BOOL;
bSmsNr6InUse : BOOL;
k: INT;
end_var
program
FOR k:=1 TO 6 BY 1 DO
IF (concat('bSmsNr',concat(INT_TO_STRING(k),'InUse'))) THEN
aForSend[3,k]:='1';
ELSE
aForSend[3,k]:='0';
END_IF
END_FOR
i get error cannot convert type string (255) to type bool
//Dennis
You cannot use concat in IF statement condition. It has to be boolean result. Thats why you got that build error.
Do the concat before IF statement and use comparison in the condition.
And in twincat you don't have to use ; in the end of statements.
What i mean IF (concat('bSmsNr',concat(INT_TO_STRING(k),'InUse')) ) THEN the result is STRING, it should be something like this IF (concat('bSmsNr',concat(INT_TO_STRING(k),'InUse')) ) = STRING_VARIABLE THEN then the result is boolean.
If you are trying to check if some of bSmsNr variables are true and then write it to string table as true, its way easier to declare bSmsNrInUse as an boolean array.
Code:
VAR
     aSmsNrInUse : ARRAY [1..6] OF BOOL;
     k : INT;
END_VAR
IF aSmsNrInUse[k] THEN
    aForSend[3,k]:='1';
ELSE
    aForSend[3,k]:='0';
END_IF
END_FOR
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
185
Gents, I'm trying get some SEW Movigear motors in control by a Beckhoff PLC which is TwinCAT 3. The SEW motor is connected by EtherCAT and is...
1,327
Gents, I'm pretty new to Twincat 3 and facing at an annoying issue when try to go online with a remote Beckhoff PLC. At out plant we have 10...
4,719
Hello: I have a TwinCAT embedded PLC and for years I was able to access it through the AMS NetID. Recently updated Windows 10 and I was not able...
16,405
I am trying to get the TwinCAT Master running on a Windows 10 PC, but cannot make it run, except in the Config mode. When I try to change it to...
7,571
