Twincat system error
anuj9326
Jun 2017
Deggendorf
I am doing a project on twincat 2.11 with CX-1020 controller which doesnt support Twincat 3. I can connect the PC to PLC and also able to upload the system configuration from the controller but the programm which is present in the controller is not accessible.I tried to to upload the program from target PLC to PC but it is showing an error that the 'Runtime is already in use' or 'source file could not be read'.The runtime port 801 is also selected in the PLC control setting but still the error is comming.I also added the multiple runtime ports but its not showing while uploading.Kindly provide me the solution for this.
In 2.11 it is not possible to upload a program from PLC, Only when ou have saved the source on the PLC you can do this.
The 'Runtime is already in use' can occur if another computer is logged into TwinCAT. This is because TwinCAT will only allow one PC at a time to be logged into the runtime. This can also occur if someone was logged in and did not properly logout, but it will clear up after a period of time.
I have also seen a couple controllers get locked into that state and the only solution was to cycle the power on the controller.
As shooter also mentioned, you will only be able to upload the program if the previous programmer downloaded the source code to the controller.
Hi, I'm working on a project that involves using the Beckhoff C6015-0010 running Windows Compact Embedded 7. Essentially, I'm trying to use the...
14,435
Hello, After two days of digging thru information system, tutorials, reinstalling everything...I think that now is the moment to ask on forum :)...
3,626
I am using TWINCat PLC to control two Rexroth Indra Drives (say drive A and drive B) via a virtual axis (say V). Basically, B has to speed up...
3,547
Hello, I am using twincat v2.11. I have different time with computer timer and Twincat system time difference about 6 hour. How need...
1,710
Hi guys, I have 4 tasks running on my CX: -Main Task 25ms Prior 1 -Serial Task 2ms Prior 2 -Visu-Input Task 5ms Prior 3 -Visu Task 8ms Prior 4...
1,725
