twincat3 problems on build version
italo2008
Feb 2009
Padova
95
Good afternoon all
I'm having some troubles trying to go online with a twincat3 project that has been developed with another laptop (I will call this one "developer PC").
I'm 100% sure that the project I have in my laptop is the actual PLC project
Build revision of developer PC an my laptop are the same: 4022.22
I don't understand why Twincat tells me that there are differences in the project (see picture: in my laptop I use build 4022.22, but in that windows it tells me that the IDE is 4022.32
I tried to compile with different versions of compiler, but no luck.
any suggestion?
Thank you
Hi, In Twincat3 x64 is it possible to get value of variable of which name is read from a string variable? VAR VAL1 :REAL:=555...
1,220
Today I had first time experience to troubleshoot Twincat3 project, that has motion control and is semi complicated and it was project not done by...
1,482
Hello I'm programming a project in TwinCat3. I'm not new to programming but I have never really programmed anything too complex. I want to...
1,733
So for my senior design project in electrical engineering my group and I are designing an inspection system using twinCAT3 as the basis of the...
1,827
Hey Everyone, hope everyone is safe and healthy. So I got my hands on the following hardware. I have no experience in programing in ST and...
6,053
