two panelview600's one micrologix 1500, possible ?
GTX
Dec 2003
36
Hello All,
I have a micrologix 1500 PLC and two Panelview600's both DH-485 (2711-T6C5L1 ser.A v4.2).
I was wondering if it is possible to hook both of them up to a micrologix 1500, so one would be in Channel 0 and one would be in Channel 1.
Is it possible ? How is it done ?
Thanks for any input !
Yes,
You could configure both ports for DH485.
Or use one port configured for DH485 and network ML1500 and both PV's together( preferred method IMHO). See PDF's
DH-485 is a network type infrastructure. It can support up to 32 devices.
You would therefore only need to tie up a single channel on the MLX 1500 and set it for DH-485. Each device would have a unique node address which would be a decimal between 0 and 31.
Hope this helps.
Thanks everyone i will try this next week when i am back at work and let you know how i make out.
I have been asked to upload an old/existing program from an obsolete PanelView600, using Panel Builder32 software, and dump it in another 600. I...
2,070
Does anyone know how to have the Panelview 600 write its internal time in seconds to a register in a PLC5/40 I want to create a monitor in the...
1,104
Gentlemen, It happened so, that one of two PV600 was stollen. I have a picture of rear label from the second PV, and I know that both of PV had...
4,937
A Micrologix 1400 has been replaced. It had the same program loaded in it after it was installed. There are 2 panelview 600's that now won't...
1,302
Hello I have a problem with Gauge Indicator. When the value is changed, it disappears scale and numeric value. Does anyone know what is wrong...
1,833
