Two Parts I need to finish
Doylen
Dec 2007
Virginia
46
Hello PLC Experts.
I need to complete these two tasks but I have limited knowledge about programming.
1. I have part counter. But I don't have rate calculation. If some has rate calculation with FIFO in AB SLC, will be helpful.
2. Is there a way to tansfer status data from compact processor to excel database not using RSLINX PRO software? Within the network, there are muliple Micrologix 1100, Compact, Panelview plus terminals.
Sincerely thank you for your help (and reading)(y)
Simple rate is start a timer when an event is started stopthat timer When the next event is started.
Doylen, I probably have several examples of Allen Bradley SLC-type rate calculations, but none of them use a FIFO, so I can't help you with that part.
Does your supervisor knows you're helping others not your company?
1. I don't have a supervisor.
2. I am helping very little, if any.
3. I don't have a company.
You question makes 3 wrong assumptions. Your PLC programs may be be full of incorrect assumptions.
Maybe someone has an idea on this. I'm looking for a 24vdc solenoid with actuator about a 2" stroke. But I need the pull to be relatively slow...
2,376
104
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,160
Hi, I searched in forum but haven't found anything similar.. I am looking for Eplan .edz files/macros. I don't have access to data portal so maybe...
1,982
Good Afternoon , I have a 5 Hp SEW Eurodrive motor S.O.# 87.8070060501.0002.22.90 KA67/T motor. I'm trying to find the Terminal Block that...
2,079
