Type X to shutdown FT view Studio
Hojland
Oct 2006
Langå
203
Hello
When I try to test an application in FT studio it says "type X two shutdown" it newer opens. Then I can restart the PC and it works for a feew times, then it write the same again
This is typical when using the "Running Man" to Test your Application in RS Studio. It's just a reminder that you can use the "x" on your keyboard to stop the Application from Running. The Testing of an Application will also Shutdown after 2 hours of Runtime and will display a warning when time remaining gets to 4 minutes. After all it's only for testing the Application.\
As far as never running it does take some time for the application to open and it does not show in the Task Bar immediately after starting the Test.
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
66
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
100
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
290
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
122
