UDT's and RSlinx
leotasca
Jul 2013
Santa Catarina
I need to know if there is a structure to communicate UDT 32 bits
directly to a SCADA software, not Rockwell. I'm using a communication
between an array of DINT, but would like to name the items within each
DINT (bit). I made a UDT struct in RSlogix 5000 and was very good, but
RSLinx can not see each UDT has the same structure of a 32-bit DINT
and not communicating, which makes my job a lot because my array will
be without any structure. Somebody used this?
If your UDT is for instance XXX.YYY (dint) the use XXX.YYY.0, XXX.YYY.1 for bits 0 and 1 and so on.
@widelto
I use UDT's for an array of Dint, where the objetive is put names for all bits off all items. Example:
Array ControlMotors (Array Of 100 positions off UDT "Motor")
UDT motor: Automatic (bit0), Semi-Auto(Bit1), Manual(bit2). This UDT have 32 Bits.
Now, I can Read a Block of DINT using the OPC String: [My_OPC]ControlMotors,L100,C1, where I have a Block with 100 positions, and this works fine.
But I can't make a Array of UDT Motor communicate, because the same OPC string is not valid anymore, and I don't know how to do this, because I think is not possible.
Look Atach files:
Array_DINT_SCADA.jpg is the OPC String working on SCADA software
Array_DInt_Logix.jpg is the array of DINT on logix5000, but I like to change.
Array_UDT_Logix.jpg is the array of an UDT. Is how I'm trying to do, but I can't make communicate with Scada, using Block's (like I can do using DINT). Only works using tag by tag....
Well, If is possible to communicate a block of an Array's UDT, solve my problem!
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
128
I am trying to copy an array of real numbers into a UDT with a real data type element. I have attached a snip below showing my COP instruction...
214
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
164
Does anybody have any samples of how to "Create and Use" UDT's in CCW Developer Edition? (I am using v22) I can't find any information from...
331
Hello, I have been looking for a reference for the order that a UDT is copied in the COP instruction. More specifically - I have a set of code...
562
