uLogic Processor Fault Code 05
snguyen
Dec 2006
Colorado
I got this fault when connecting to a 1761-L32. The PLC was initially programmed using APS ('97). I am currently using Logix500 v7. Although I am able to clear the fault, when I put PLC back in run the same fault reoccurs.
Does anybody have any suggesions on what this means and how to fix it?
uLogic fault code 05 is: RETENTIVE DATA HAS BEEN LOST
The data files (input, output, timer, counter, integer, binary, control, and status) are corrupt.
• Cycle power on your unit.
• Download your program and re-initialize any necessary data.
• Start up your system.
• Contact your local Allen-Bradley representative if the error persists.
In addition to clearing the fault, the PLC's status table must also be resetted.
Goto to the PLC's Errors tab and manually put a 0 in the Rententative Data Loss S:5/8 register.
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
101
Is there anything I Should take into account while updating the firmware on a safety processor? I have a 1756-L61S running version 17 and need...
106
Hello all, I have been experiencing dropping network connections on the Co Pro quite a bit, 3 times a month. The remedy that we do to bring the...
760
I have an application where I will be using two PanelView Plus 7s to run two machines that share a common processor. The machines are identical...
404
So I have an interesting question. I work with sites that don't have controls tech's and wanted to know if its possible for a processor to be...
1,226
