Ultra3000 error 04
loundeb2
Jul 2010
ny
111
I have an AB Ultra3000 servo drive, 2098-DSD-030 hooked to an AB F4075-R-H00AA motor. This has worked fine for two years. Today an error 04 kept constantly repeating after about every minute of running, which I know is a motor over-temperature error.
In Ultraware the motor temperature shows between 7-12% rating and current at 10.5amps average while running. The motor is physically cool to the touch and the drive temperature is 0%.
The wiring has been checked and is fine. Is this a drive problem or a motor problem?
Thank You,
Lou
Hi
I had a good few of the dsd-20-dn and -sn go down with this fault and it was always the drive. I would have sent the drive away and got them repaired up on till lately were the plant were I had the problems shut down.
Donnchadh
Hello, I have an issue with one Ultra3000 servo drive. I command an 1326AB-B520E-S2L motor and after 30 min the drive goes to fault with the E22...
1,653
Ok so first allow me to bow my head and say I'm a retired mechanical engineer and while I still have a few brain cells left there is something I...
3,975
Customer has an issue with an Ultra3000 that gets the E19 error as soon as power enable is active and it tries to home. Input 1 is Drive Enable...
5,852
Hi all, we have a machine that running for more than a year and recently we have often times problem with position error. base on your...
2,093
Hello all, I am currently trying to setup an Allen Bradley Ultra3000 drive connected by SERCOS link. I have played around with all the settings...
5,086
