UltraWARE Software
Uxie
Oct 2021
Ohio
I'm looking for the Allen Bradley UltraWARE software for an old Ultra series servo drive.
I'm working on a senior project at my university and I need to get a working servo motor for our machine. Our project advisor provided a 1398 Ultra series motor and we found a 2098 Ultra 3000 drive. Unfortunately, there was no product key provided and we cannot access the software through Rockwell Automation. Despite several calls to their support and local distributors, I was unable to obtain the software.
If not, is there any hope of running the servo motor (Y-2012-2-H00AA) on a different drive? If so, with what and how?
Any help would be appreciated!
Welcome to the forum.
the Ultra series software requires a license key as you have already said.
you may want to contact your local distributor to see of you can still buy the software OR if they have a pc with the software loaded that you can borrow.
james
james
I hadn't thought of seeing if I could borrow it, but it seemed like none of the distributors I spoke with had it on hand.
You can get it free from this link from the Allen Bradley site.
https://compatibility.rockwellautom...2&refSoft=1&toggleState=&versions=51858,50195
Check the box under Accessory Files then click the Downloads button at the top.
Wow! I didn't realize I was actually able to download that, thank you! None of the Rockwell guys I talked to over the phone mentioned it. That begs the question though, what is the software that actually requires the serial number?
It has been an obsolete product for many years now and their tendency is to make the software available without an expectation of getting support.
Anyone know the catalog number for ordering Ultraware software to use for interface with AB Ultra 1500,3000 and 5000 drives Thanks
3,502
hi i try to connect mpl-a320p-h (motor with brake control) to the ultraware3000. i have problem when i turn on enable in indexing mode, the...
1,064
I bought myself a CNC machine for a home project and it has an old AB Ultra 3000 servo drive in it. I need to get online with it and tweak some...
1,830
Hi All, I having some problems setting up a new drive using Ultraware. The application is a simple bucket conveyor that indexes along each time...
2,381
Hello, I am working with an ultraware servo and I would like to interact with the motor by sending a digital signal to specify a velocity...
1,194
