Unable to connect FTV SE to SQL EXPRESS Server
dNaverio
Feb 2023
Como
Hi all,
I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express.
I state that they are installed on different machines connected via LAN
I tried to run some tests using FTV on the machine where the SQL Server is installed and everything worked just fine, but via network i can't create a connection neither on Data Logs nor under System\Connections\Databases.
I created a ODBC Data Source File, both in the local machine and where the server is running and I can establish a connection without any problem
I assigned it to my Data Log, I wrote down the login credentials and i successfully created my Tables inside the DataBase, but when i press the OK button a "Connection failed" popup appears
Does anyone have any idea?
Thanks!
Edit: Solved, the problem was the firewall. After setting it Off everything worked.
Later i will search for a solution that will allow me to mantain it On without causing trouble.
Till now I have in/out rules to allow connection on ports 1433, 4022, 135, 1434, 443, maybe I missed something?
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
137
Hi, I have recently been making some online program changes to a Q00UCPU plc. I have been using a USB to USB-B connector. And have been happily...
745
I admittedly have never set up a Rockwell Thin Client / ThinManager but I need to step in because a vendor is having trouble making the connection...
675
Hi, First i'm a beginner and not a very good in english so i will try my best to be clear ! I work on an used installation and me and my team has...
672
First time using SE and I'm stumped on this one. I've developed my app, tested it within Studio to a live PLC, I have a valid license. Running...
3,187
