unidrive sp analog out question
jugenzhu1963
Jun 2006
toronto
72
Hi
I have a question regarding unidrive sp analog out. I have a sp0205 driver which control a motor using close loop vector mode.
The speed referance coming from HMI. one analog output from driver go to siemens analog module EM235 which send the speed display to HMI. This analog output hook up to driver's T9 terminal. The parameter Pr 7.19 points to Pr 3.02 which is drivr's speed feed back. The value of Pr 3.02 is negative number.
But when I measure from EM235 terminal I got positive voltage value. The question is this voltage should be positive or negative corresponding to Pr 3.02 negative number?
I check the Plc program which scale the analog value properly. The problem is that when I increase the speed reference the speed display on HMI decrease. The analog voltage( positive value) from driver increase fellow the speed reference accordingly. But inside PLC I do see the input value decrease. why?
Hi, I have a question regarding an analog output that I just cannot understand, if anyone can please help out I greatly appreciate. I’m replacing...
45
19,383
hello everyone, trying to find a way to read/write memory of the PLC that is inside Unidrive M700 over Ethernet (modbus TCP) using device/server...
572
Greetings experts, We have a 'Control Techniques' Unidrive 3405 in an older machine. It appears that the drive parameters are recorded in a .CTD...
740
Hi We intend to replace our LENZE EVS9326 EP with a Control Technique Unidrive SP. The machine is a simple one; PLC send ABZ pulses to the drive...
2,066
Looking for a Modbus address manual for M700. Modbus address is same as the Parameter number for 16Int parameters. But it is different for 32Int...
2,011
