Unity program different and we can't recover
DebPeterson
Apr 2010
Houlton, WI
31
I did some work in a unity program offline, and now its different than what is in the processor. I can't seem to recover, short of doing a straight down load to the processor, but we have equipment running that can not be stopped right now. I can’t transfer (up load) the Program from the Processor either, I keep getting a E5006 processor failed error. Anyone know how to recover from this?
Check in the folder where the .stu program is, and look for a .sta file called program name.auto.sta it will be a backup of the last time the program was built. You should be able to open this and then go on line.
Don't understand why you can't upload, I have never seen this error message
Ive had some issues like this before. Mostly when you wrote software and used the hardware catalogue with user devices and then upgrade to a newer version of unity. You must export the user devices before upgrading. Sometimes the hardware catalogue doesnt have those devices and wont be able to upload then
Unity program wont upload.
Thanks for the replies, we ended up loading unity 6.0 (our orginal program was developed in 4.1) and we were able to upload the program without any problems. Not sure if we will need to do an upgrade or what. Still dont know what the error means. Thanks much, Deb
Hi I have an a applcation with SE M340 and ATV61. I want to control frequency and start and stop the ATV61. I have a correctly configured...
2,693
We recieved a unity program from a vendor and it was developed using 5.0 we use 4.1 at our plant. cannot open or view, wondering what are my...
2,436
In the old DOS days (and early Windows) there were key stroke programs available. Program a key combination to insert a string. Does anyone know...
19
10,456
We are in the process of investigating the conversion of a program written in ProWorx 32 to Unity. I am after info on the tips,tricks and hazards...
4,140
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
191
