Unity Simulator & Magellis
rosscodye
Dec 2011
Sydney
I have Unity Pro running a PLC simulator (Schneidere Premium). That works fine.
The target environment has a Magellis HMI.
I want to test the HMI on the Unity Simulator.
Can anyone advise:
- driver to use
- config details
- adressing details for PLC points
Ross
Sorry schtiel but dont you have to enter the ip 127.0.0.0 in vijeo designer or is this the same as entering the local pc's ip adress?
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,937
Hi, The simulator panel shows the Scada is connected. However, the pages don't read any tags at all. The PLC and Scada are taken from the live...
1,077
So I create a virtual M580 PLC in unity pro software and I have connected the virtual PLC with OPC client which is installed on another computer...
1,076
I'm using Unity Pro XL v13.1 Trying to connect to the PLC Simulator and getting error: "This isn't a valid PLC Address, or PLC is budy, or media...
2,771
I am using Unity Pro 13 XL- running on windows 7 OS. The program is in Simulation mode. When I try to connect it to the Simulator , I am getting...
5,584
