plcsoftvsd
I am looking for a Function block for this logic in unitypro...
INT value greater than or equal to 10 and less than or equal to 20 then output = high (1)
and added to this is hysteris of 2 which means no change in output even if value is between 20 to 22 and 8 to 10.
The output starts at 10 but does not fall off till 8 and same is valid at higher end 22
It seems there is a FBD available in Unitypro specifically for this temp control application but i can't get around it.
Any ideas are appreciated.
