Updating a counter .ACC value in Studio 5000 in Function Block
n0pe
Aug 2017
Canada
Hi there,
I have been using ladder logic for quite some time on a variety of AB products. I've switched to function block for a lot of things lately, and I've noticed one difference that I haven't found a solution for in FBD.
On ladder, if you want to update a counters .ACC value, you can click on it and enter a new value, press enter. Easy. On FBD I have noticed this value is read-only. Is there a place within studio where you can update this value online without triggering the input?
We are using RSStudio 5000 v32.
Thanks in advance!
It is an extra step, but click on the ellipsis button and you will see the parameters. I believe you can change it there.
OG
Thank you for the reply. I have entered the parameter box and I see the parameters, however they are read only. I think this may work if I put the PLC in program mode or make the changes offline, but my hope was to find a solution that would work online as this is a running system.
https://imgur.com/1HMB7KI
When they are grayed out like that, it means that there is a wire connected to that pin. If you remove the wire, you should be able to adjust the value.
How about creating a dummy compare instruction [NEQ CTUD_08.ACC -1]
Then see if you can change the value there. On the road without Studio5K today so I can't test the theory - but I will tonight.
Excellent! That's what I was looking for. I will have a chance to test this out tomorrow morning and report back. Thank you for your answer.
Hello, I have a panelview plus that reads from 4 different PLC's. 2 of these used to be Micrologix PLC's and someone else went and updated them to...
125
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
115
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
151
Is there anything I Should take into account while updating the firmware on a safety processor? I have a 1756-L61S running version 17 and need...
117
Hi, I'm trying to figure out how to properly update the "icons" on my Panelview 900 (AB 2711-T9C9). I think maybe I'm having a fundamental...
1,026
