Upgrade step5 to step7
Alpha
May 2003
35
Hi, everyone,
Ours PLC is step5(CPU928B, with IM308B conect to ET200U, CP525 communicate with PC), we want upgrade it to step7:
Does ET200U can use in new system?
Do we need a CP module to communicate with PC(Current loop)?
I have try to config the system with S7v5.1 HW config like this. In this system I try to use CP440 communicate to PC.In the picture, you can find the ET200U, but I have not ET200 I/O module in my catalog.
Thanks.
Hi Alpha,
You've got several options, you could re-use your old S5 I/O and simply change your CPU. Or U could replace your complete PLC. When you go for the last option then you've got several option concerning the communiction with the PC. A good replacement for the CP525 is an ethernet connection (CP343-1 or CP443-1) if you would like to use Profibus then you need an Profibus FMS for pc connection (CP343-5 or CP443-5)
Bye
For some reason, this PLC system is a part of the DCS, This DCS use VALMET(usually used in papermaking) system, and we can not modify this system's design. So we had to keep the current loop communication and originally PROFIBUS device.Thank you.
Does anyone know if exists upgrade for Step5 v7.17 to v 7.2 (or higher)? If, then where can I find it? Thanx for any reply...
1,658
How much the upgrade for NT2000/XP cost there ? Here dutyfree is around €557 ? This STEP 5-BASIS V7.2 works with all MS-OS from DOS to XP-Pro...
3,323
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
199
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
278
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
211
