upgrading network to ethernet with 5/05 processor
alexbeaum
Oct 2012
québec
I upgraded mostly of my processors to 5/05. but I got 3 processor left that I still need my DH-485 to communicate with some optimizers. I wanna put my 5/04s on my ethernet network.. So I wanna buy 3; 1761 Net-Eni ser D .
I was wondering if the MSG block (RSlogix500) will be functional to communicate between a 5/05 and 5/04 under ethernet channel?
I made a simplified diagram of what I wanna do.. Does I understand right?
http://dl.dropbox.com/u/45365194/shema1.JPG
THX :site:
I don't recall how the Net-ENI handles MSG's but dont use the NET-ENI, it only has something like 4 concurrent connections, and has problems releasing them then locks up requiring a reboot. Digi makes a better unit from what I've heard with 64 connections.
http://www.digi.com/pdf/prd_ds_digioneiap.pdf I also don't know how the Digi passes MSG's but I know the NET-ENI has caused me trouble everytime I've run into it.
Yes, you can message to/from a SLC behind a Digi or Net-Eni. The NET-ENI should support up to six total connections, but max of four in either direction. Digi uses a single connection for all comms as far as I can tell. We use both. We like the Digi better.
In your diagram, you show a 5/04 connected to a DH485 device and an RS232 device. The 5/04 has one serial port and one DH+ port. It can use the DH485 protocol on the serial port, but not DF1 at the same time. So, to do what you want, the 5/04 should be a 5/03 unless the DH485 and optimizer are really on DH+?
My mistake.
The optimizer communicate with a DH+ protocol.. The processor is a 5/04..
So, DH+ protocol for my optimizer and Rs-232 for my DIGI/NET-ENI.
thx a lot.
and I think I'll go for the Net-Eni, find some good price on ebay. The digi are a more expensive and impossible to find used, To be honest my budget is pretty low..
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
440
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
562
I am looking to upgrade some of our old Servo Drives to the newer kinetix 5700 style. currently we have 4 1394 axis that are all driven by 5kw...
898
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,138
Hello everyone, My company has an old line for building DC motors. Many machines are from the early 90's and some requests for safety...
1,166
