Upload S7-300 program via profibus
CQ21
Apr 2021
Columbia
61
Hey guys!
I have a S7-300 plc and I wish to upload its program to my PG and create a backup. I have a siemens simatic pc and have set up the PC/PG interface correctly bc I have tested with a different cpu. It is a profibus connection but when I try to upload the program I receive this error (see pic). Does anyone know what it means? Can I ignore it? Not getting the error when I try uploading with a different cpu so I would like to figure out why that is the case...
Thanks in advance!
Ah the famous (2000) error. It usually means you don't have one or more software packages installed that is required for a module in your hardware configuration.
In Simatic Manager, click on the top most object in the tree on the left side, right click it and click Object Properties...
Click on the "Required Software Packages" tab, and click the "Execute" button at the bottom. Paste a picture of the result here.
Thanks for your reply. I see...should I select continue and then check for required software packages (I don't have the original program)?
I have got a Panel View 300 (2711-K3A19L1) which is currently being used on a production machine. I have not got access to the panelview program...
7,428
Hello everyone, I had question regarding Step 7 Pro 2004 and S7-300 CPU. I have finished programming the CPU (port of AB program to S7...
6,492
Hi, Expect: we have SIEMENS PLC S7-300: CPU 313C (6ES7313-5BG04-0AB0). we don't have any software to upload its program. we just want to upload...
23
7,889
Hi guys, Newly installed CPU 315 2 EH14-OABO .Today I was trying to upload the program to PG then I see one message coming. Kindly see the...
8,626
I have had several instances where contractors have come in and updated an S7-300 program that was configured in TIA V13 but failed to leave me a...
2,482
