Use an Encoder with 120VA Micrologix 1200.
gzPLC
Oct 2018
Texas
39
I want to use 24vdc encoder with an existing micrologix 1200 PLC,
The plc inputs are 120vac, I need 120vac for my other inputs.
So is there any way I can have 24vdc high-speed inputs for encoder and rest all 120vac inputs?
How should i make this work?
I don't think a 120 vac input unit has the high speed inputs for an encoder only the 24vdc input units, I know it is this way with the 1400's
You can use 24vdc coil ice cube relays with 120vac on your contacts but as roxusa said I don’t think the 1200 120v unit has high speed inputs.
Edit: the more I think about it the less likely I think this will help you. How fast will the encoder be spinning or how fast is the device shaft spinning?
I want to use 24vdc encoder with an existing micrologix 1200 PLC, The plc inputs are 120vac, I need 120vac for my other inputs. So is there any...
2,544
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
302
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
365
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,078
