User defined tags
Earl
Sep 2014
Pittsburgh
I'm rebuilding a panelview app and have a question.
Control Logix will be the platform,
I have a screen that shows data for the last 10 event snapshots, 8 points of data each line. I built the screen using individual tags for each data point (80 tags) but I have heard that I should use a user defined tag instead. I am having trouble making it and can't really find an example that shows what I am trying to achieve.
thanks
Thanks,
Thats not a manual we had around the shop, and they do not allow net access. Thank god for alternate means of reaching out.
Ah, one of those places. Surely it's only a matter of time before places like that die out for lack of access to information and we can all get on with living in the 21st century ;)
You don't necessarily need to use a UDT to store data like that; an ordinary 2-dimensional array sounds like it would work fine and it's even easier do to indexing and searching.
Let's say you have eight floating-point values for each Event. Make a 2-dimensional array tag called EventLog[10,8].
The first index value will be 0-9 and that will be the Event number.
The second index value will be 0-7 and that will be the Data Log Entry number.
So if you want to display the third entry from the tenth Event, the tag address would be EventLog[9,2].
im not understanding how these user defined tags work. i want to assign local tag data to udt please guide
9,022
Hello again, My problem is that a company sent me some program changes to install. It tells me to add a few tags under UDT>SYS_FAULT. When I...
3,010
1) I am poor 2) I have written some useful plc code in the past 3) Anyone here ever try and sell a user defined FB?
29
6,686
I am working on a project on an s7-1200 with an hmi, but I am looking to remove the HMI and substitute its functionality using the User-Defined...
1,935
Hi all, is there an easy way to reset a user defined shift register to 0? i have a data type containing 8 bools for an array of 10 and would like...
3,211
