Good Afternoon ,
I'm using a Compactlogix 1769-L18 , with a 1734-IK , and a BEI Incremental Encoder . I'm able to get the encoder to count , if I rotate by hand , but when I run a 1725 rpm motor at 30 HZ , I don't recieve any counts in my "Present Data " .
FYI , the BEI Incremental Encoder is 5-15 vdc , the 1734-IK is rated for 15-24 vdc and my power supply is set to 15.3 volts.
I run it as low has 5 HZ and it still does not want to count. What do you think would be the issue ?
Thanks in advance ,
Thanks in advance ,
