using a mitsi plc to get data
AndEdtec
Apr 2002
Wales
78
What I need to do is read and store a time under a certain condition.
I'm not sure if I need a fancy "hmi" to do this.
I have a sensor which is made on every cycle or operation "every minute" a machine does, I have written a rung with the condition, each time the sensor comes on it starts a timer which is say 30 mins. If the timer is allowed to ellapse then I simply want to record the time.
I have a few ideas but was hoping for a point in the right direction.
I don't really want to use a Hmi, i just want to collect my time with my PC.
Andy
Not quite sure what you want to do; Do you want to know how many times the machine has been idle for 30 mins or do you want to know the total time?
You could set the timer to pulse a retentive counter each time it times out. Then make the timer reset.
Then monitor the counter for the number of times the timer has timed out. Make provisions for the counter to reset itself above a certain number in case you leave the company or die.
(That was an attempt at humour BTW)
machine idle
What i actually want to do is know when a machine is idle.
is there anyway of getting a value from a clock and when it's idle to store the time i.e 12.00 pm and another flag could store the time it starts in a data register.
i thought about building a clcok in ladder with timers and counters but surely there must be an easier way.
hope this is a bit clearer?
There is a way to do that, but off the top of my head I do not know the exact D register to MOVe. Which brand of mitsi is it, not all have internal clocks.
I will get the book out to check the registers the time is stored in.
If you are using a Mits Fxon, you will need a real time cassette ( Fx-RTC )
The data will then be stored in the following D registers.
Seconds D 8013
Mins D 8014
Hours D 8015
Date D 8016
Month D 8017
Year D 8018
Day of week D 8019
I've never used a RTC my self, but i hope this helps
Regards
Lightning UK
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
38
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
79
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
134
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
249
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
79
