Using a SLC as a data logger... is it possible??
Rob3192
Jun 2010
NYC
I figured by using 200 files (float) and each file holding 256 pieces of data i can get over 5 days of storage....
what do you guys think ??
thanks
I am trying to write data from Citect to a SLC 5/04 and having some problems when i compile. I am trying to create and add a genie to an existing...
2,983
Hi, We have any enquiry on a imaging checking system which is using Coreco camera & software. It's working with an AB SLC. But I'm not sure...
2,833
Hi, I'm hoping to use an SLC 5/05 PLC to communicate as Modbus RTU Master to a number of Modbus TCP slaves. I understand that a gateway is...
4,293
I'm pretty sure I know the answer to this, but thought I should ask. Over the years, when I'm given a SLC project, I'll load it in my test 5/05...
1,410
I have 4 outputs which cycle off-back on, one at a time if more than 1 output shuts off I need to set an alarm I`m wanting to use the compute...
1,907
