Using Eprom In Plc
RODELF
Jan 2005
URMIA
HI
I AM THE USER OF SIEMENS SIMATIC S5 115U .I WANT TO RUN PLC FROM EPROM.BUT I ENCOUNTER WITH SOME PROBLEMS:
1) THE ANALOG CARD CAN NOT CREAT THE REFERENCE VOLTAGE FOR SPEED VARIATION OF MOTOR.( BUT IN RUNNING WITHOUT EPROM THIS PROBLEM DOES NOT OCCURE ).
2)HOW CAN I COPY ALL THE EPROM TO RAM OF CPU?
THANKS.
The problem is: you are trying to read and write the value that is stored on the eprom. The value has to be in memory. To read a program from the eprom can be done with a "Prommer". It will alow you to read the prom to a laptop and modify it, put it in the CPU, monitor, etc. As far as removing the eprom and leaving the program running, you could do what I have seen others do, while the CPU is running, and power ON, pull the eprom out. DON"T put it back with the power on.
Hello, I have a one off job to modify some Siemens Step5 software at a local factory. The PLCs are S5-100U (CPU103). I have uploaded the PLC code...
4,301
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
33
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
66
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
128
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
226
