Using FSC instruction in Controllogix
ettikudiappan
Apr 2002
Singapore
131
I am having trouble using the FSC instruction in RsLOgix 5000. I want to search an array in a single scan and only on a rising edge. So I have an ONS instruction followed by a FSC instruction in "ALL" mode. The first time the rung-in condition goes from false to true, the array is searced alright. I reset the inhibit bit whether a match is found or not. But when the rung goes from false to true again, the FSC instruction is not executed. I have overcome this by reseting the found bit and also setting control.pos to zero. My question is, is it right way to use the instruction? From the help files I gather that I need to reset only the inhibit bit to start another search.
The FSC stops searching the array on the first true comparison and sets the IN and FD bits. Provided the rung remains true, resetting the IN bit will enable the search to continue from the current position to the next true comparison or the end of the array. Once the whole array has been searched, the DN bit is set.
Your use of the ONS is probably unnecessary since the FSC is initiated by transition. I assume you wish to search for the first true compare only and start all searches at the beginning of the array. To accomplish that, you should reset (RES) the control tag and unlatch (OTU) the IN bit before each initiation of the FSC. For completeness, unlatch the FD bit as well.
beerchug
Hello, I'm brand new to the forum and I have a frustrating problem at work that I've been trying to find a solution to. I have scanned the...
11,217
I received the following message via PM, and am posting here publicly to help others. ============================================ I had a...
1,026
Good morning everyone, I'm working on a project where I am recording data from a machine by sending it message packets. Most of the time the data...
2,153
Good afternoon. I have seen many ways to monitor and reset alarm conditions but most seem to use a lot of logic that I think can be simplified...
4,367
I am trying to search an array using an FSC. I need to check for two varible within the array to make it work. Right now this is the only way I...
1,185
