using iHistorian for reporting
Aug 2005
singapore
Hi all,
Im using iFIX 3.5 SCADA,my requirement calls for reporting with some mathematical calculations mostly averaging over time like for every one minute, hour, day etc..
Can any one advice me if i could use iHistorian to collect the data and later extract the information collected and do some mathematics over that through excel or some other application?
If some one can provide examples of the same (or) link which has those examples it would be of great help
iH & iFix
Hey! I wouldnt complicate things with historian since iFIX has strong scripting tool VBA. You can implement this calculation inside VB script, create a form that represent your report and display this calculated values on a that form ... That is the solution that we often use ...
Bye
Hai Saravanan,
Yes it is possible with Ihistorian for FIX. I am currently working on this area.
It will be more useful if u could add Sytech's XLreporter to make further reports.
Regars,
Prasanna.
Mobile : +91-93426 71622
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
38
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
83
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
138
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
263
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
79
