Using MSG Instruction
eyespyral
May 2004
Can anyone tell me how to use the MSG instruction to send a message from a Micrologix 1000 to a PC (connected serially using DF1)? I'm not sure how to set the parameters, or even how this is really suppose to work. Thanx.
You sure Can
I have some code that works great using a PC and Micro 1000.
Contact me privately if you want the details.
I can zip the file and give it to you if you wish.
Where are you located?
kcarlen,
if you're willing to give it away, why don't you post it here instead of dealing with matters on a private base? This forum is all about sharing knowledge, maybe the downloads section is the place to handle this request.
I for one would have given the info there if I knew the MicroLogix myself. I've done some ASCII communications between CompactLogix and PC and between SLC5/03 and PC, but I've never used a MicroLogix.
Kind regards,
No prob guys. I didn't plan to make people angry.
I just don't know the best way to post the RSS file. I would just like to post a file concerning the messaging. What is the best way to do so?
If your file size is big(>307kb) you have to zip it first.
In the attach file at tab at the post reply click on the browse button and point to the file, then click submit reply.
This is the steps to make an attachment
What do you mean by sending a message to a pc from the micrologix? To my understanding and from my practices I have only used the MSG instruction ultimately from controller to controller. I however have programmed HMI's with Visual Basic( a cheap alternative to propietary hardware) and had the pc connected serially through one of the PLCs and then had the PLC's networked with what ever hiway was available and shared the information as required by the customer. As for MSGing directly to a PC, with AB product try discovering the RSLINX server capabilities.
Hi all, We have a packaging machine in our plant that has a cartoner and the casepcker. If caspacker goes down for 5-10minutes this shuts of...
1,718
Is it possible to use the MSG instruction to grab all the information from an analog module (e.g. 1756-IF8I/A) that is owned by a different CPU...
3,787
Hello All I have a Kinetix 5500 Drive connected to a CompactLogix 5370 controller. There are 3 ways to access servo-specific attributes -...
3,536
Hello All, is there any way to fetch remote controllers Mode Run/Remote Prog/Faulted etc. ( AB L8 Series) using CIP message, if yes please share...
845
Hello Ken Roach, Thank you for your quick reply , As informed earlier i want to read P&F Sensor data on Micrologic 1400 series B using MSG...
17
5,854
