using omron serial port
rafpars
Apr 2009
tehran
hello every body.
i have a cp1h omron plc and i want to comunicat with MONTRONA madule"BY 125" from serial port .i never write a program that use serial port with txd and rxd.i read the by125 manual and serial progarming of cp1h but i can't write a true program.
plz help me .
thanks alot.
What have you been able to do up to this point?
What is your exact problem?
Do you have the proper cabling?
Omron pin out is NOT standard.
We will be happy to help, but will not do this for you.
Is it possible converting Omron and Keyence plc's serial communication into Ethernet using serial to RJ45 converter? I need to connect these plcs...
2,273
Hi all, When using serial comms, I've usually used the Omron protocl to connect to a CJ1M. After checking the driver help in Citect 7.20 it has...
7,162
Hi all, I have a problem connecting Omron CQM1H to my laptop using USB to Serial. (my laptop come without serial port). Anyone can help me...
8,088
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
291
Hi All, I aim to use Aveva Plant SCADA 2020 to read and write data from/to Omron CJ2M CPU35 PLC using OMFINS protocol. However I have Bad Data...
732
