Using Studio 5000 Emulator with a virtual HMI
Shane.platt
Jun 2017
Tucson AZ
19
Hello All!!
Sorry, the topic was a mistake I meant to say with a physical HMI!
I have seen this question asked elsewhere, but I can't find the post anymore. I have a Automation Direct EA9-T7CL-R HMI with a Ethernet connection. I was hoping I could use the HMI to interact with a Studio 5000 Emulator program running on my pc on the same network as the HMI.
I have been just forcing bits and manually adding values for DINT and Real inputs. But it would be a lot easier to use the hmi. Any suggestions???
Have a great New Year!!!
S
Hi Shane.
Unfortunatley no- I dont think you can do this, however this sort of functionality is available with the SoftLogix platforms.
Regards
Daniel.
Not with a cmore. You can use emulate with FTView. I've used emulate with AdvancedHMI, using opc though. I'm sure emulate would work with anything that supports opc.
Thank you Daniel and Phrog for the quick replies! I am going to research the SoftLogix and AdvancedHMI to see if I can make some headway on this.
Exposing shades of “newbie”…. I haven’t used arrays much, and I think using one for multi-zone temperature control is probably the solution I...
796
Studio 5000 & PF 525, Ethernet Comms, Encoder FB, Using Motor RPM as speed reference I'm trying to figure out how to send a speed reference in...
939
I'm looking at trying to program Relay Ladder Logic to average out a value for X amount of time. In this application I'm looking to have an...
3,045
Dear Network, My purpose is to test a application created with Studio 5000 view designer using view 5000 Emulator and Logix Emulator. I created...
6,107
Hi all, I recently was upgraded from Win7 machine to a Win10 machine with lots of horsepower. Last Friday, I tried exporting a routine and when I...
4,679
