Using UTP Patch cord cable instead of IE cable
Adenitz
Feb 2010
tir
41
Hello guys,
can I use RJ 45 UTP Cat 6 patch cable instead of Industrial Ethernet? The connector is broken and there wille be some deliver time to get identical replacement.
Original cable is this one.
And I have 10m patch cables like this one..
This cable is not shielded, but length is only 10 m and most of the cable is placed inside the control cubicle.
I have tried and it works, but wonder if there might be some restrictions or safety issues I need to watch out.
Thanks!
hi i would use a cat6 or 7 cable and make sure it is not routng past VFD cables or solenoid valves etc and then replace ASAP with correct one
+1
A cat 7 is the same and should cost less, also the Siemens cable is too rigid, you need a pipe bender when installing :)
Should be fine for now, but to avoid weird noise issues you do want to replace with a shielded cable at some point.
Hi, I wrote a sequence loop using EQU and MOV instructions and would like to validate that i'm doing this properly. i attached a picture of the...
525
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
55
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
97
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
159
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
310
