variable speed control for 1ph motor
lesmar96
May 2017
PA
520
I have a customer that came to us, looking for a variable speed control for a 115V motor
He bought a 115V vibrator. The motor is a cap start. According to my understanding, it is not trustworthy, or maybe not even possible, to vary the speed of a single phase motor.
I read this thread
http://www.plctalk.net/qanda/showthread.php?t=117583&highlight=1ph+vfd
and it has strengthened my understanding.
Am I correct? Is there any new controls any one has heard of to do this or is it even electrically possible?
Any advice would be helpful. Thanks.
No, there is nothing new and it's mainly because if you vary the speed of a capacitor start motor, the capacitor re-engages and can damage the VFD, the capacitor or both (it becomes a race to destruction, the winner making you a loser no matter what).
See if you can replace the motor with a 230V 3 phase version and then get a VFD that takes in 115V single phase and puts out 230V 3 phase. There are dozens of them on the market.
How much draw does the motor have? I'm going to hate myself for suggesting this, but you could try using the capacitor or leading edge type fan controllers that are used on ceiling/workshop fans. All the stuff we get here is good for up to 240V/10A - Yep, hate myself already.
Also, am I the only one who laughed? Giggity.
This makes sense with what I was thinking as well, I am just young without a lot of experience and wanted some verification. It seems you could start it at full speed to get the start windings to disengage, then you should be able to slow it back down as long as the centrifugal or electronic switch doesn’t kick back in. But that only seems to be asking for trouble as you have mentioned.
The manufacturer of the unit told my customer that they can sell a variable speed control for this unit but it is very expensive. He bought the unit figuring he could buy a control elsewhere.
It make me curious what the OEMs plan for varying speed is, but I don’t think I can recommend anything.
I'm looking at a Home Depot ad, an 8 amp 115 volt vari-speed motor control.
But I'm with Jraef - the capacitor would probably fry it.
Can the motor be replaced with one of similar power which does not have
a starting capacitor?
The Home Depot says Model # AVS-8 115. $78.75.
Poet.
Does anybody have any experience/suggestions for variable speed control of single phase motors? My application is: Control up to 4 - 1/2hp fans...
20
6,711
I have two Variable Speed pumps in a Duty/Standby configuration. Only one pump runs at a time, controlling to a pressure setpoint. A new stream is...
9,172
We are going to be installing these controllers to control boiler feedwater pumps. 4 of them total for the first project. I have never used...
5,805
V
dear all.. i am designing the Sea Water Intake pump which the 4 pumps will be operated parallel, and 1 pump will be as stand by pump The pump data...
161
We have an application where we need a joystick to control a VFD. Off in the center, 0-10V in forward and 0-10V in reverse. Also with auxiliary...
2,330
