Velocity and flow issues with Rexroth HACD
saultgeorge
Jul 2015
Detroit
536
Hey, folks. Here's a good one. Hope one of you pros can shed some light on this. I'm doing a job where 2 hydraulic cylinders work alternately to dispense slurry to make foam car parts, the foam stuff you find under your hood that deadens sound and wraps Freon lines. The cylinders supply a system that mixes other materials after the slurry is dispensed and then it goes through a mixhead and gets dispensed into a mold. The dispensing set-up and mixhead are on a robot, and I don't control any of that. My only task is to get these cylinders to dispense a certain volume (grams) in a certain time (seconds) with my PLC program.
Instead of using a PID, the company has these HACD controllers made by Rexroth. We are a Rexroth dealer.
My immediate question is this: The cylinders will not dispense a uniform amount of slurry and it hasn't hit the weight setpoint yet. (36/grams per sec) Every time it dispenses slurry, it's called a "shot". We discovered two lines plugged in the mixhead, and then we also determined the mixhead was plugged. The cylinders have a 1,500 psi limit. The company says that isn't the problem, the shot should be correct. The slurry circulates through the mixhead when not called for a shot. Since it couldn't circulate, I believe that the HACD's cannot compensate fast enough at the 1,500 psi to give an accurate volume.
Anyone had any experience with this and has some insight to these HACD's? Besides the 722 page manual. Thanks for reading and for your help. Attached please find spreadsheet used for volume/sec calcs and a snip of the logic to send to the HACD
  • Cylinder Flow Rate Calcs 032318.xlsx
Not sure what the final answer was but the spreadsheet has the wrong formula for the area of the cylinder. In calculating the radius, they did not divide the diameter by 2.
It's also unclear how the system coordinates the accel/ decel of the two cylinders when one takes over from another but generally giving them the same acceleration and deceleration and starting the change at the same time will work.
It's been a while since I've done the calculation but to determine the airflow velocity (rough measurement only) do I use the following formula...
3,449
Hi guys, I have the first Kinetix 5100 in my facilities. I already configure the movement in Speed Mode, I am sending the Analog signal from my...
66
Hi all, I am having a problem with my servo motor and I'm absolutely stuck as to why it wont run. Without any gearbox or any load attached to...
3,856
Hello, I have a reactor with a cascaded PID control for control of the batch and jacket inlet temperature. We throw in all the required...
1,761
A query for the motion control experts: I have an app where I measure the position (encoder ∝ K * angle) of a rotating device, and use that along...
3,798
