Versa pro and CPU351
jcp
Feb 2010
Multan
369
Hi friends;
I want to know if i purchase versa pro and the previous programme is develop in LM90. first i convert it into versa pro. I want to ask is there any firmware or other issu to load store and communicate with CPU351? OR same configration may be used?
Regards
If you are planning to purchase programming software, the current offering is called Proficy Machine Edition. Versa Pro is one generation old.
Both Versa Pro and Machine edition have recommended minimum firmware levels for each CPU model, although an earlier than recommended level may still work just fine. Firmware upgrades (free) for you CPU model are available at the GEIP support site.
Good Day, I am hoping someone can help me. I saw from some earlier posts that you converted a Versa Pro program to a pdf file for another...
1,706
When I want to store the hwc file to the PLC an error apears and said the firmware 5.03 is incompatible with versapro, and the minimum version...
3,170
Hi. Hopefully for Steve Bailey. I saw from some earlier posts that you converted a Versa Pro program to a pdf file for another member. I am in the...
3,221
hi where can i download ge versa pro ?
1,608
I have a 90-30 PLC file which I think was developed using Versa Pro (P80 in the Uk)with the file extension .z3x Ive tried opening it with machine...
3,071
