Versamax Micro64
Bob.K
Nov 2005
Ohio
35
I would like to replace the inner workings of an obsolete annunciator with a Versamax IC200UDD064 Micro 64 PLC.
I would like to use the chassis and cells of the old annunciator by wiring the PLC outputs directly to the Incandescent lamps for proper annunciation. My question: our distributer told me that incandescent lamps have a fairly high inrush current especially when the filament is cold. I intend to use 2-24MB bulbs per output and the bulbs are rated at 70ma each. The Versamax Micro outputs are rated at 700ma. Will the inrush current be too high for this type of output? the plc will turn the lamps on and off until the alarm is acknowledged which could be several days in some cases. Thanks in advance
Not sure what type of bulbs but you could replace the incandecent ones with LED ones. Similar to illuminated push buttons and such.
Better illumination and will last a life time.
Thanks for the info. I had been looking at the LED's for some time now but was concerned about whether the light load of the LED would not load the output down enough to compensate for the leakage current which would keep the light off when the output is off. Our distributer says that the light load problem is mostly inherent in AC circuits using triacs and not the dc output transistors. The LED's are coming down in price but still not equal to incandescent. At $12.00 a pop (Newark) it takes some convincing of those who are more accountable for the bucks than I am. The LED's are approaching the cost of the PLC.
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
234
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
144
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
404
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
445
I have a new computer and it doesn't have an ethernet port. I am trying to connect to the Versamax Micro Plus with a type c to ethernet adapter...
1,267
