Versamax to PME conversion
AB_PLC
Jan 2007
Oklahoma
I have a project I'm converting from Versapro software to PME on Versamax platform.
So far it looks smooth. I have no way to verify Modbus simulation from Versamax PLC. I can't seem to understand how the PLC talks to other devices via the modbus port. The logic and addresses are hard to follow.
Does anyone know how the devices correlate with the addresses or how the variables listed in Capture1.jpg are assigned to serial ID's. Maybe point me in the direction of where to look.
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
222
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
138
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
396
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
435
I have a new computer and it doesn't have an ethernet port. I am trying to connect to the Versamax Micro Plus with a type c to ethernet adapter...
1,257
