Version management
quadPLC
Feb 2010
Milwuakee
51
I work for a company with hundreds of PLCs in the field. There are probably 70-80 S7s in the field.
Each runs the same software, but maybe a different version as different machines come online. We don't have a very good means of doing version management so I was wondering what others do in industry.
As of right now, we have tried normal source code repositories (PVCS, SVN, etc.) but they are meant for uncompiled code. It doesn't seem like there is anything out there meant for PLC code.
We try to put version numbers in the code, but sometimes people forget to up revisions in the code and such. It just makes the whole process complicated.
Discussion on process would be nice.
Thoughts?
One method we use is to include the revision date in the source code file name. As we often update systems or make em do something different depending on customer demands. This helps but is by no means an end all solution. We also use a log book for all PLC changes or programming changes.
For S7 programs we use this DIY method although it still relies on manual updating....
Embed the date of the latest modification in the main Project object name.
Create an STL source file to use as a modification record (after all they're only text files).
Also embed the date of the latest modification in the name of the mod record file.
Add a new section to the mod record on each update.
When archiving ensure the archive file name also contains the date of the latest modification.
We are doing like like KRK, but have the log file where we store the archive file,
Nice solution to use the source folder for the logfile, going to introduce that for some customer.
We use the following date format:
2010-01-02_Filename here.ext
Where the date is Year - Month - Day.
In this way a group of files will always sort by revision date.
As a systems integrator dealing with multiple customers on various versions of products, how in the he$$ do you manage development/implementation...
2,255
Hi Everyone, I am facing an issue while installing the STUDIO 5000 in my windows 10 PC. During installation I am getting an error that " Error...
55
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
63
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
228
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
219
