vfd drive
mss8378
Mar 2011
1.i need run torque speed 300 nm.what type of drive i can select?
2.what are the type drives?
3.how to calculate the torque valve in drives?
Please list the following info
Load torque demand (I think you did 222ft lb)
RPM of load
What type load ie constant torque (crane conveyer) variable torque (pump etc)
Motor nameplate data
Available power volt freq phase
Crystal ball is broke.
Dan Bentler
RPM of load
Dan Bentler
Dan, I saw this reply of yours in another thread just now "Uhhh Crystal Ball man - you got any spare batteries for your crystal ball I can borrow?"
http://www.plctalk.net/qanda/showthread.php?t=63492
Didnt he lend you any?
Havent seen any batteries appear - should I check mail box or UPS?
If crystal ball can give magic answers with no data input should not batteries just magically appear?
Dan Bentler
Dan Bentler
No. Crystalball, while very powerful device, is just for data viewing, not matter generator:cool:
I have a customer with a Garment Hanger Conveyor who intends to put 2 drives inside a panel and a 3rd drive out in the field by the motor. I would...
1,568
alright guys i got a good 1 for you is there anyway to get the parameters off the HIM on at 1336 VFD drive from 1994. The drive is burnt out can...
2,386
Hi Folks... I am considering connecting a braking resistor without a brake unit, to the terminals P/+ and N/-- of this 22kw, F-700 Mitsubishi...
22
6,258
Hi! Would it be possible to replace an induction motor (VFD controlled) with a stepper motor and drive? Are there any advantages by doing so...
2,923
Typically our 700h drives get the freq output number from the Plc by multiplying the percent speed, ex. 50% x 280.86 which writes to a predefined...
3,025
