Viba plc
You can use Simatic Manager v5.5 to program Vipa PLCs.
As far as I know the MPI cable is special.
But most VIPA PLCs have ethernet onboard, so that would be a much better way to get online.
You are correct Jesper. Vipa uses a special cable called "Green Cable" but you can also use the standard MPI cable.
I guess Vipa calls it "Green Cable" because its Green. :p
hello iam using citect together with a modbus driver. if i want to select bits this is not possible. digital is reading from a different adres...
1,630
Hi all, looking to model old RR relays in PLC. Does anyone have any SPECIFIC examples on how to model a relay such as a polar relay, slow pickup...
70
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
63
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
258
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
146
