Vickers Servo Drive
Oct 2004
Southeast Missouri
I have an application that has a 3 axis servo drive by Vickers. The controller is an open frame computer of some sort. The drives and servos are Vickers. I can't find any info on Vickers drives and servos on the web. We want to swap out the computer for a Control logix plc. Does any one know if this can be done without changeing the servos and drives?
Also the local AB rep came up empty on any info on the Vickers...
John
The CLX analog servo control cards should be able to control any servo amplifier that accepts the correct input signals for enable and speed reference. You would need two 1756-M02AE servo modules.
Quote from AB manual:
The Analog/Encoder Servo Module
(1756-MO2AE)
The Analog/Encoder servo module provides an analog/quadrature encoder servo drive interface. The servo module receives configuration and move information from the ControlLogix controller and manages motor position and velocity.
The servo module supports:
• Connection capability for up to two drives
• ±10V analog output
• Quadrature encoder inputs
• Home limit switch inputs
• Drive fault inputs
• Drive enable outputs
• 5V or 24V position registration inputs
• 250 µs position and velocity loop updates
A/B has several other motion control cards for CLX including a hydraulic motion controller with LVDT inputs.
You will have to find out if your Vickers amps meet these requirements in order to keep the existing drives and motors.
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
80
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
113
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
106
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
77
Hi, I'm thinking about using commands for Melservo J5 controller via HMI without PLC. Have you guys done this kind of control configuration for...
152
