Vijeo 6.2 difficulties...
LupoTB
May 2011
Lethbridge
Hello All,
I have been dropped into a hornets nest of a project. The orignal venodor has been kicked off site and I've been hired to complete the job. The PLC is a Schneider M580 and the HMIs are HMIGTOs. I have managed to complete the work on the PLCs and everything is running perfectly, but am having difficulties with the HMI software. Namely, I can't connect to the PLC with the Vijeo sotware. None of the drivers will load.
The original vendor will not give us the HMI files, so I am having to recreate it from scratch. I have never worked with this software and am under a time constraint so my stress level is approching maximum.
The tutorials are pretty thin for Vijeo (at least for what I need). Are there any resources I can get to quickly that will get me over the hump here?
I have the screens built, and faceplates made, but nothing is linked to anything yet as I can't get online.
Any help will be greatly appreciated.
never mind, figured it out.
Here's what I have so far.
So my only hangups now are how to make the faceplate link to all hte motors and how to get online with the PLC.
Thanks,
L.
you should be able to zip it?
If you send me a PM, I can give you an email to send to.
You could also send some screen shots of your config perhaps? Both PLC config & HMI settings
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
82
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
217
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
215
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
494
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,698
