Vijeo Citect 7.2 - OMRON Digital Datatype not updating in real-time
thorshz
Feb 2017
philippines
Hello,
We have this SCADA system Vijeo Citect 7.2 Windows 7.
PLC: OMRON C200HG
Protocol
UNITY MODNET30
OMRON OMRON
OFSVIJEO MODCELL
All communications are good but DIGITAL data (TAGS) from OMRON is not updating in real-time. (Need to restart the Vijeo Citect to make it work).
*OMRON: BCD & LONGBCD datatypes are working good and showing real-time (voltage, speed current)
*OFSVIJEO: INT datatypes are working good.
*OMRON: DIGITAL datatype is not working in real-time, I mean I have to re-start SCADA program to make it work.
:site:
Please help... thank you
This means that everything works for a specific time? How long?
Have you contacted the manufacturer of the SCADA?
It looks like this is a continuation of the following thread.
http://www.plctalk.net/qanda/showthread.php?t=107912
It's working fine, I mean all other data are continuously updating(like temperature, voltage, current) BCD, INT datatypes.
It's not updating when there's a digital input signal to the plc like alarms and some ON conditions. That's the time we need to manualy close and restart the Vijeo program.
We got no response from the manufacturer.
thanks...
Hello, Kindly help me on this PLC-scada issue. Newbie here. We're on the ship and our scada PC (IPC APAX-5571) suddenly won't boot anymore (no...
5,866
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
48
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
489
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,687
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
898
