Vijeo Citect to Powermeter PM800
hadihidayat
Mar 2010
Batam
Hi all,
I want to connect Citect directly to PM800, without PLC, is it possible?
I have try in Vijeo citet, but there is no PM800 (PowerLogic - Square D), in Express communication wizard - external device.
i beg your help. thanks.
Yes it is possible, just use the standard citect modbus driver
thank you sir.
but can you explain me more; what external device which have to selected in the communication wizard? what variable tag which have to added, to read the value from PM?
thank you for your help.
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
17
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
487
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,682
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
898
Hi everybody, I have a simple question for anyone who knows.We cant try because system is working and we dont have a permission about it. We have...
737
