Vijeo Citect
meghnesh
Jan 2011
Gujarat
82
Hi.
I am trying to connect Allen-Bradley SLC 5/04 with Vijeo Citect over DF1.
In Vijeo Citect I used the DF1 Drivers and KE500 Protocol.
But now when I am trying to address an Integer Tags, I am getting error saying "Bad IO Device Variable"
What should be the ADDRESS FORMAT for INTEGER & DIGITAL data types for such DF1 IO Device ?
Thanks in advance
Hi meghnesh, do a search using "Citect to SLC500 communication help required" you will get the info required to connect a PLC to Citect via serial RS232 (DF1). Re addressing, you use the same as SLC500/RSLogix500, i.e internal bit digital= B3:0/0
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
71
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
490
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,689
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
900
Hi everybody, I have a simple question for anyone who knows.We cant try because system is working and we dont have a permission about it. We have...
739
